I need to call PurchEditLines form for picking list and get some lines from some purchases like pushing select button at PurchEditLines form. I couldn’t found anything about this.
I just found create picking list from purchase code…
Fix for writing mistakes:
I need to call PurchEditLines form for generate one packing slip from some lines of some purchases like pushing “select” button at PurchEditLines form. I couldn’t found anything about this.
I looked up purchformletter class without any success…
any opinion???
Updated because of bad english:
You can run PurchEditLines and select some lines of some purchases with select button. I just want to do this with X++:
1-Select some purchases with purchFormLetter class (I just succeded select one purchase).
2-Filter some lines of these purchases. (I couldn’t succeded)
3-Show these at PurchEditLines form.
This is my code part:
l = purchformletter::construct(DocumentStatus::PackingSlip);
args.object(l);
args.record(tmpPurchTable);
args.parm(VendReceiptsListJour.ReceiptsListId);
mf = new menufunction(identifierstr(purchformletter_packingslip), MenuItemType::Action);
mf.run(args);
There are more than one record at my tmpPurchTable temporary table but it see just one of them. Also I need to filter some lines of these purchases, I couldn’t find out a way…
Please, I’m waiting an answer…
I hope I could tell me at this time…
Found solution. It was hard for me to find out:
Object formRun;
Args args = new Args();
PurchFormLetter purchFormLetter;
purchTable purchTable;
VendReceiptsListTrans ListTrans;
PurchParmLine purchParmLine;
PurchParmTable purchParmTable;
select purchTable where purchTable.PurchId == this.PurchId;
purchFormLetter = PurchFormLetter::construct(DocumentStatus::PackingSlip);
purchFormLetter.parmSourceTable(purchTable);
purchFormLetter.initLinesQuery();
purchformletter.createParmUpdate();
purchformletter.chooseLines();
while select OrigpurchId from ListTrans
group by ListTrans.OrigPurchId
where ListTrans.ReceiptsListId == this.ReceiptsListId && ListTrans.OrigPurchId != this.PurchId
select purchTable where purchTable.PurchId == ListTrans.OrigPurchId;
purchformletter.updateQueryAndChooseLines(purchTable);
ttsbegin;
while select forupdate purchParmLine
where purchParmLine.ParmId == purchformletter.parmId()
select firstonly ListTrans where ListTrans.ReceiptsListId == this.ReceiptsListId && ListTrans.OrigPurchId == purchParmLine.OrigPurchId &&
ListTrans.ItemId == purchParmLine.ItemId;
if (ListTrans.RecId == 0)
purchParmLine.delete();
update_recordset purchParmTable setting num = this.ETGpackingSlipId where purchParmTable.ParmId == purchformletter.parmId();
ttscommit;
purchformletter.reArrange(true);
args.name(formstr(PurchEditLines));
args.caller(purchformletter);
formRun = ClassFactory.formRunClass(args);
formRun.init();
formRun.ETGfromVendReceiptJour(this.RecId);
formRun.run();
formRun.wait();
The above code was in ax2009. I was struggling a lot to write above code in Ax2012 ( posting of multiple sales or purchase orders to a single sales or purchase invoice.
Pls, help me… if you get any solution.
Thanks a lot in advance…
Daxing
Sorry, my case was with 2009, I haven’t got tried with 2012…
Hi ,
Could you try in Ax2012 and help me … i tried but, only blank form i am able to get. But for 1 SO i can popup the posting form(SalesEditLines Form).
Daxing
Sorry, it was four days work just done with 2009 for me… I need a big spare time for try this…
Maybe you have to get help from experts like Martin Drab…
This code was wrong for ax2009 too. I fixed it, maybe it would be run for 2012 now:
change these lines;
formRun.init();
formRun.run();
formRun.wait();
with these:
dialog = purchformletter.dialog( );
dialog.run() ;
dialog.wait( );
if (dialog.closedOk( ))
purchformletter.run() ;
