HI
I have created dataport which imports data from csv file to staging table.
once it gets imported in staging table the codeunit will validate the records and then it will be show to user in List form.
but am not able to call the list form from OnPostXmlport trigger of the dataport.
admin1
2
What did you try? And which NAV version?
admin1
3
And moved to the developer forum.
What does it mean, you are not able?
Following resons could be implied:
- You are not able means you get an error message => Post your error together with your request
- You do not know how => tell us about it, else we cannot help
- An empty list is shown => check if data inserted in staging table
- wrong list is shown => check what form you are running
