I need to get an AX 2012 report to PDF with code. I found some samples:
dynamicsaxgyan.wordpress.com/…/
first one doesn’t run, second one gives “Parameter executionInfo cannot be null or empty” error.
Any idea or sample?
Any idea or sample?
One more sample: http://dev.goshoom.net/en/2013/11/printing-reports-from-code-in-ax2012/.
I’ll rather help you with code I wrote than with somebody else’s code. [:)]
Thank you Martin,
I’ll try this at Monday. What about printing for just one record? Should I try send record with args? I didn’t use AX 2012 reports yet, I was a 2009 developer…
Thank you,
it works…
I’m getting an infolog message “Report successfully saved …”
How can I supress this?
controller.parmShowDialog(false);
useless for this infolog message…
