On my Dynamics NAV 2009 RTC Page I have an Action (ActionItem) with properties:
RunObect: Page Extend Text
RunFormView: SORTING(Table Name,No.,Language Code,All Language Codes,Starting Date,Ending Date)
RunFormLink: Table Name=CONST(Item),No.=FIELD(No.)
RunFormOnRec: No
When you press the action (or use the shortcut ctrk+t) the action opens the page “Extended Text” with a filter on the current “No.”.
That’s fine, now I want to execute this action by C/AL code (on a OnAssitEdit or OnLookup trigger)
The reason:
The Extended Text Lines get concated into a 1024 Text variable on shown on a uneditable multiline page. But Multiline Text-Boxes allow only 3 Lines on RTC Pages, this is sometimes not enough, so I want to display a OnAssistEdit button beside the field that does the same as to select the action
Side Notes:
No, promoting the action is not the same
No, tell user to use short cut will not work either
