Calculation of Line Discount at time of Purchase Invoice Posting
HI,
At Time of Purchase Invoice Posting, Line Level Discount Amount is posted in the Purchase Account I don’t want to Post Discount in system.
EX.
Purchase - 1000
Disc- 100
Net -900
My voucher is posted by 1000 Dr. and 100 Cr. in Purchase Ledger.
I want to post Voucher of 900 Dr.
Any one can help me for this Issue.??
Thanks in Advance.
Hi …
Could you try doing the following to see if this helps as the discounts can be accounted for in different ways …
AX2012 …
For the item that you purchased, it will have an item group attached (SWM > Setup > Stock > item groups >)
Under the purchase order fast tab … and the account type ‘Purchase, discount’ … if you have a main account assigned, then remove it and test the results. If you don’t have a main account assigned, please assign one and test the results.
I am hoping one of these settings would answer your question, if not … I hope another member of the DUG site can help you here.
Regards
Martin
HI,
Martin
Thanks for your reply.
I tried out Both way.
When I will be attaching Discount Account in Item group>Purchase fast tab(Purchase,Discount) System Post discount amount in that Ledger. Voucher entry is like this way.
Purchase - 10000
Disc (10%) - 100
Net - 900
Purchase A/c Dr. 1000
Discount A/c Cr. 100
Vendor Cr. 900
And When I remove Discount Account in Item group>Purchase fast tab(Purchase,Discount) System Post Voucher like this way.
Purchase A/c Cr. 100
Vendor Cr. 900
Thanks & regards,
Ankit Soni
