Calculate Depreciation Batch Job find a error inb NAV 2013
Calculate Depreciation Batch Job in NAV 2013 I fond a error " Can not find starting date in Accounting Period".
if anybody have solution then please let me know.
Thanks in advance.
Mantri.
hi,
Check the Accounting Periods, if each entry has a Starting Date.
Hi Mantri
You may have unticked a month. Tick it and try again .
Verify this if it worked !
Hasitha Jayasuriya
Usually it can happens when u forget to add tick symbol in month or else forget to mention starting date. rectify these errors and you will get your code work.
Have you created accounting period for which period you are calculating the deprecation.
