calculate age
hi all,
i have two fields birth date and current date(systemdateget())…
i need to calculate the age of a particular person…based on those two fields provided.
what would be the logic for this requirement…
Ur replies would be very much thankful…
static void Job9(Args _args)
date1980 date1 = mkdate(01,01,1990);
real calcdate;
calcdate = (systemdateget() - date1)/365;
info(strfmt(‘Age in years: %1’, num2str(calcdate,2,0,0,0)));
this might help you…
We can use yearDIff(Date 2, date 1);
But its return only the Integer value; ie 25;
For age we no need fraction value ( If u want faction too start use above chaitanya’s code)
I hope its help u to solve ur pblm
for more clarity on age …to be displayed in decimal values…we can use
“num2str function”
