Several machines on our network have the same version of the C\ODBC driver installed on them. The Option Field Type setting is always set to Text whenever a DSN is created using this driver. However, some connections will still only return integer values regardless of the option field type setting. Can anyone help?
I find a solution for this problem. When you use the ODBC Setup, you just have to press on the button OPTION. click in one field and just press OK. For one off my customer it works very good Stéphane VABOIS
