C/ODBC needed
I need to transfer the contents of our Navision database over into a SQL database. I understand I can do this using C/ODBC, yet I’ve mislaid the CD. Any idea where I can get a copy? Thanks.
In your NTR or NSC [;)]
Is this a one off, or do you need to do it regularly. If one off, you could buy the sql server option, (or have your nsc do it) and do a one off restore. If you plan this on going, i suggest moving to sql, this will make life much easier. If you do want to go with odbc, then please follow Arthurs advice, the reason being, that there are many versions of c/odbc, and only your nsc will know exactly which one is needed. using the wrong one is not a good idea.
