Hi All, i’m doing a new project on VB.NET linking to navision database.So i was creating a datasource linke to Navision ODBC,when i did it give me first ,than i press next so it’s now trying to retrieve tables it give this message <An error occured while retrieving the information from the database: Column ‘TABLE_CAT’ doest not belong to table tables.>then i put cancel than i try again it put this message <An error occured while retrieving the information from the database: ERROR[S0000][Microsoft Business Solutions ApS][Microsoft Business Solutions-Navision ODBC Driver]ISAM Error the driver doesn’t support the version of ODBC Behavior that the application requested(see SLSetEnvAttr)>.please if anyone can help so urgent.thx alot
C/ODBC doesn’t work with the standard system odbc tools in VB.NET what you have to do is reference the adodb tools from VB6 and it will let you connect.
