I have a error when i try to conect with C/ODBC 3.60 , the error is ------------------------------------------------------------------- Reserved Error (-7716); there is no message for this error ------------------------------------------------------------------- I try whith C/ODBC of 3.70 and giveme the same error thanks
It depends on what you are doing… remember that the ODBC driver for Navision is not allowing all normal SQL syntax, but a limited one.
