C/ODBC and update table
Hi all. I have a problem with C/ODBC. An external procedure update a table using C/ODBC. Sometimes an error occured during update instructions: ODBC Connection FAILED. If restart ext. program, it runs ok. I have navision 3.70 with the last c/odbc driver. The external procedure use MSAccess with DAO component. The ODBC driver is checked with readonly=FALSE and runs on W2K server. I don’t have any idea… [B)][B)][B)][V] thanks.
Is it possible that you already opened the connection? If you are telling me it doesn’t happen everytime, this may be the problem.
i had some of this errors before i put 2000 into the cache field in the odbc-dsn-options … after that it worked fine out of access …maybe a hint
Thanks Alexander. I try this way and program run better. Some errors occured too. I set cache = 1000 and try. I hope…[^] Thanks.
