I writed an *.asp page with ADO components. Here I have a following problem:
- When I use dsn with space in it’s name and call ADODB. Connection to specify it’s connection string,
cncodbc.ConnectionString="DSN=Sample C/ODBC 32 bit"
,error “Microsoft OLE DB Provider for ODBC Drivers (0x80004005) [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified” occurs - if I use connection.execute (with SELECT statement) or ADODB.Recordset.Open(with SELECT statement and AdCmdText property or with table name and AdCmdTable property),
rscodbc.Open "SELECT * FROM 'Buffer plateb'",cncodbc,,,AdCmdText
following error will occurs: Microsoft OLE DB Provider for ODBC Drivers (0x80004005) [Navision a/s][Navision Attain ODBC Driver]Table does not exists
