Hi Is there anyone out there with any experience with connecting to a Navision Financials environment running on AIX, UX or RELUX? My obvious question is: Is it at all possible? All logic will say that it makes no difference which platform the server run on. Regards
if you using CF on windows OS any problems, no matter that type of server you have. You wanna use CF on Unix ? If you use CF you need run dll or ocx (both are 100% MS) How you gonna run it ?
It should work on any type of unix NF servers as no matter wether the NF server is unixoide or Win NT all your Navision clients are MS Windows based and that’s where the DLL or OCX is registered. As yet there’s no NF client for Unix workstation. tarek_demiati@ureach.com
