C/AL Object problem.
i can’t run “vendor card” in “form” and this display this message: ‘the C/AL Object was not saved in compiled form. Compile it from the the object designer and run it again.’
then, i can’t find it in “Table”. i have the table number 25 then a Table number 27.
You have to check Table Number 23 for Vendor
Compile the object and check.
thank you mr Amol for answer
Welcome
If it solved your problem then Click on Verify Solution button to verify the answer so it will help others.
