Hello,
I’m working on modifying some of NAV reports and forms. I’m able to access C/AL editor for the reports but coudn’t access C/AL for any of the forms. All C/AL code, Globals and Locals choices under View menu are not active.
Any specific reason for that?
Fekre
I think it’s because you don’t have the Form Designer granule (7120) in your license.
[Edit] Actually 7120 just allows you to design the Form, as you have done. You need Application Builder and / or Solution Developer to access the code on the forms (depending on which form).
http://dynamicsuser.net/forums/p/31386/164179.aspx
I do have 7120 Form and Page Designer (includes 100 Pages & Forms). any thing else?
You might not have seen the edit: Actually 7120 just allows you to design the Form, as you have done. You need Application Builder and / or Solution Developer to access the code on the forms (depending on which form).
Looks like that’s beyond my control. Thanks anyway.
You can purchase it / them for your license, but they are not cheap.
