What is the code for Run-form propertys like,
- Run-object , 2) Runform -link 30 runform-linktype…
i want to write code for a button inplace of using these propertys…
plz help me out…
Regards
venu
plz help me out…
Regards
venu
Can you please rephrase your question?
There is no “code” for these properties.
You have basically two options to run a certain object from a command button in a form:
Either you define the properties mentioned
Or you put C/AL code into the “OnPush” trigger of the command button.
Which way do you want to go?
Hi Venu,
Have a look at the C/AL function help of RUN and RONMODAL as I think this it what you are looking for. As Thomas says we would need more information to help you fully
Instead of using those propertys , i would like to go vth code in ONPUSH trigger.
Can u plz specify the code , tht i can write in onpush trigger , whch functions just like , property settings…
This mainly depends on “what” form you want to run and “which” record with “what” filter you want to apply.
If u dontmind , Plz explain me wth a example of Customer & customer ledger entrys …
Hi Venu,
declare a variable for the Cust. Ledger Entry
set the filter you want on the Cust. Ledger Entry variable
e.g.
“Cust. Ledger Entry”.SETRANGE( “Customer No.”, “No.” ); // Similar to RunFormLink property
FORM.RUNMODAL( 25, “Cust. Ledger Entry” ); // Similar to the RunObject property
Hope this helps
