Hi everyone,
Can anyone enlighten me on the by-product production. My input is just one raw material but my output can be 3 by-product, the ratio of the by-product cannot be fixed, only estimate because the raw material and finished goods UOM is in KG, thank you so much
Dan
The standard AX doesn’t support production with multiple outputs.
You need to look into - AX Process Manufacturing which comes with formula management and can handle the co-by products requirements.
But even to implement that you should have a standardized process…
Thank you Kranthi,
I also heard about AX Process Manufacturing, do you have any document about this? Or the training material?
Dan
You can download them from the partner/customer source…
