Kindly help from where I can set 'Operating Unit Number" when I create a business unit.!?
Jainal
Jainal
Hi Jainal,
General Ledger >> Setup >> financial Dimensions >> Financial Dimension >> select business Unit >> Select Financial Dimension Value then opens a form where in you can define your desired number for operating units
If u find helpful, kindly verify solution…
Thanks Ashwin for such detailed answer.
But over there ‘Dimension Value’ field is non editable.!
And I want to know from where such number automatically generates.?
Kindly help for this.
Jainal
Hi Jainal,
OK in General Ledger >> Setups >> Organization >> Select Business Unit and create the number that you want and the same can be seen under financial Dimension Values of Business Unit …
Just check this Once …
Thanks Ashwin,
I tried that earlier as well but over there number automatically generated.
So I want to go in the route where we are assigning our own number series.
Please help in that.
Jainal
Hi Jainal,
If that’s the case, go to Organization Administration >> Number Sequence >> In the AREA field select Organisation >> Click on edit >> Under General Tab change it to Manual by default It will be Continuous…
… Verify the solution if you find this apt …
Thanks Ashwin,
This works.
Can you please further guide in which parameter we are applying this number series.?
Jainal
