Hi Everybody,
I’m trying to extend a table called “Tax Entries” but i could not find related table in my VS Code Editor so i could not do any extension.
Please advise.
Best regards,
Riksa
Hi Everybody,
Please advise.
Best regards,
Riksa
This is most probably the table VAT Entry.
It is just the caption which is changed for NA version as Sales Tax is used there.
Thank you very much!
Anyway that i can find the metadata relationship between label name and actual name for page and table?
Run NAV 2018 Dev env, open Object Designer, show column Captain.
You should always have a NAV Dev Env open for referencing and checking the code in the Base Application.
I’m running development environment with docker and i’m still new with docker so i’m sure yet how to open NAV DEV Env.
But thanks for the heads up!
Cheers.
