Bulk data import (multiple datasets) / using .dat .def approach
Hello due to migration of data we would like to import bulk data into AX 2009. We are using the standard import function with .dat and .def files. Excel import is not possible due to incompatibility with Office 2013.
Our approach was to first export some data e.g. for articles, than manually modify this data and add additional data sets for other articles and import again.
It works perfect when only importing one data set per .dat file at a time (.def file has exact structure as during export) However we did not manage to import multiple data sets at one time.
We suspect that this is related to the max/min record id values in the .def file. Is there any way to do bulk data import?
Thank You
Florian
