Build Field Name In C/SIDE
Hello all, Is it at all possible in C/SIDE to reference a field by building the field name in a string, i.e. : Record."Field Number " + FORMAT(1) := ‘Hello’; Any help appreciated. Jonathan
Jonathan, there is a possibility using RecordRef and FieldRef variables, which are a little cubersome to use but once you get the idea it’s quite simple. There is some information in the help, or you can download a sample from http://www.mibuso.com/dlinfo.asp?FileID=276 Saludos Nils
