Can someone help us find where and how budgets are accomplished thru Navision? Any help is much appreciated. Hank
The first place you should start is use Navisions ONLINE Help. Click Help->Search->Budgets - It should have a ton of topics for you to read.
The budget is kept in separate entries and can be set up with different filters. If you open the budget form you need to set the filters to the desired detail level. Then you can enter the budget amounts.
