BOM
In the Bom list there is a “version list” at the under-header . My question is that what is difference between “version list” and " and “BOM line” which is up-header???
Thanks.
hi Baris,
The version list is the list of versions in that particular item.
Example:
ITEM Version BOM Lines
Item number 001 Version 1 Item 2 with 2 kg, item 3 with 3g
Item number 001 Version 2 Item 2 with 1.5 kg, item 3 with 2.5g
hope this help!
Schneizer
If you change the BOM lines you will loose the previous BOM lines information. This method work fine if you find that the BOM lines have been set incorrectly and you want to correct it. But in the case where your company want to adjust or change the BOM components, this method is not suitable because you will loose the previous BOM components once the new changes have been saved. Usually, company will want to keep the original BOM components as reference when adjustment or changes are made to the BOM. Rather than create a new BOM for the new formulation, Navision allow you to update the existing BOM with version.
Note: The Active Version field in the Production BOM card will show the currently active version.
many many thanks for yoru answers:))
Welcome…
