bom version
Hi everybody,
In the BOM Table, one BOMId can have more than one version, however when I created the Bom Versions, the two versions have the same BOM line. How can I provide the different BOM LINES for each BOM VERSIONS.
Thanksss.
Here the version means the BOM items that are using the selected BOM Id, so they will have the same BOM lines configuration, changing the BOM lines here will effect the all items that are attached to the BOM ID. A BOM item can have multiple bom version(which will be having different BOM id’s), where you can have different BOM lines per each version.
Thank you so much Kranthi…it is more beneficial for me :slight_smile:
