BOM journal
In what situation, the BOM journal is recommended to use? Is it basically the same feature as the produciton picking list journal?
thanks,
When you do not use the production module
So, basically BOM journal has the same impact on inventory level and financial posting as production order?
Create a Bill of material journal in Inventory to receive the finished good into inventory and issue the component items.
This journal would typically be processed using the production module.
No not at all, but if you do not want the complexity of the process and the module you can short cut kit the movement of stock using the journal.
