Dear all,
I have BOM lines for item XYZ.
item quantity
xxxx 10
yyyy 5
zzzz 10
At quotation stage how can i know what is ON-hand quantity of these items to create planned purchase order.
Dear all,
item quantity
xxxx 10
yyyy 5
zzzz 10
The system will consider the ON Hand QTY while generating the Planned Orders (if these planned order are generated by running the plan - plan should considers the quotations and on hand). They will not consider on hand if you are creating the planned orders manually.
I don’t think you have an option to see the on hand availability of the BOM lines at this level. But you can have a look into On hand reports…
The ATP will be available, but there is no drill down on hand due to the nature of the quote, when it is a sales order there is a committment so you can run it into the plan, in essence the plan can also look at quotes, but the theory of having a detailed answer causes many problems, your quote tells you that you have the stock to make 5 immediately, they confirm the quote 6 days later and you have no stock because it has been consumed on real demands, which is why at the quote stage it is the price that is fixed for x days and not the delivery timescales which are very fluid depending upon the business you are in.
