Blocking Previsous Month Orders to change..
There is a need to block the users to change the Sales Orders if it belongs to previous month.
EX. if Order no A is made on Feb system should not allow users to make any change in it.
I was trying to get it with several ways but unfortunately not able to get the exact solution.
Hi Vijay,
This is not possible as standard but you can achieve through coding. Does the control need to be on all orders or just released?
If released you could add code to the re-open function otherwise on the ONMODIFY of the order table but this seems extremely severe.
I would suggest sitting down with the customer and explain the pitfalls as I suspect as soon as this is implemented you will need to reverse or workaround the restriction. Otherwise the user may key the order again and the orders will have duplicates
