blocking creation of Free text Invoice for a customer whose invoice yr & membership no has already a invoice posted.
Dear All,
I have following query :
Scenario: I have created a module name membership module where i have option to generate unposted free text invoice . the parameter which i provide in my batch of billing are invoice yr, membership num . Each membership num is attached to a customer . so my batch creates a FTI in AR> FTI with combination of these fileds. i have already added a invoice yr and membership num filed in my CustInvoiceTable. Now once a invoice created through my batch is posted it should not allow the creation of another invoice of same combination until and unless it is reversed. when i reverse that invoice and then create another invoice (of same combination) and post it, till here its working fine…2nd time after creation of invoice and posting i have not reversed it, but here is the problem, it is allowing me to create the FTI of same combination which should not happen.
simply, If my invoice is reversed i can create new invoice. after creation and posting it should not allow me to create new unposted invoice.
Kindly help where i am missing.
following code i have written.:
public void run()
GOD_PrimaryMemSubscriptionFixedRate fixed;
GOD_Membership membership,god_memberShipSelect;
GOD_MembershipType type;
// KK Modified
CustTrans trans;
CustInvoiceJour jour;
// KK Modified
CustInvoiceTable custInvoiceTable,custInvoiceCheck;
CustTable custTable;
CustInvoiceLine custInvoiceLine;
ServiceCodeTable_IN code;
int lineNum;
CustInvoiceLineTaxExtensionIN custInvoiceLineTaxExtensionIN;
GOD_MembershipNumber currentMemberShip;
GOD_MembershipPostingProfile god_Post;
container conLedgerDimension;
AXCustInvoiceLine line;
AxCustInvoiceTable intable;
Struct struct;
container ledgerDimension;
DimensionDefault defaultDimension;
real calcValue;
int DiffYear;
int i = 0;
int j = 0;
GOD_Membership gOD_Membership;
GOD_MembershipNum gOD_MembershipNum;
GOD_GrossSalesTurnover gOD_GrossSalesTurnover,lastGSTAmount;
real calculatedAmount;
GOD_PrimaryMemSubscriptionRate gOD_PrimaryMemSubscriptionRate;
boolean insertEntrance = false,interNationalFlag = false,gstAmount = false , nGstAmount = false, reverseTrans;
GOD_BillingCycle goD_BillingCycle;
str 2 quaters;
GOD_InternationalSubscriptionRate internationalSubscriptionRate;
line = new AXCustInvoiceLine();
intable = new AxCustInvoiceTable();
struct = new Struct();
ttsbegin;
while(queryrun.next())
ledgerDimension = conNull();
conLedgerDimension = conNull();
gstAmount = false ;
nGstAmount = false;
membership = queryrun.get(tableNum(GOD_Membership));
custInvoiceCheck.clear();
// KK Modified- 18/12/2014
trans.clear();
// For inactive members -KK modified -12/24/2014
if(membership.MembershipStatus == GOD_MembershipStatus::Active)
// KK modified -12/24/2014
select * from custInvoiceCheck
where custInvoiceCheck.GOD_InvoiceYear == InvoiceYr
&& custInvoiceCheck.GOD_MembershipNum == membership.MembershipNum
&& custInvoiceCheck.OrderAccount == membership.Customer ;
select * from trans where trans.Invoice == custInvoiceCheck.InvoiceId;
reverseTrans = TransactionReversalTrans::findTransactionReversalTrans(tableNum(CustTrans), trans.RecId).Reversed ;
// KK Modified -18/12/2014
// if (!custInvoiceCheck) // KK Commented -18/12/2014
if (reverseTrans|| !custInvoiceCheck ) // KK Modified
calculatedAmount = 0;
gOD_MembershipNum = membership.MembershipNum;
select fixed
where fixed.MembershipType == membership.MembershipType;
select god_Post
where god_Post.MembershipType == membership.MembershipType
&& god_Post.Region == membership.Region;
if (membership.DateOfJoining >= str2date(“01-Jan-”+int2str(InvoiceYr),123) && membership.DateOfJoining <= str2date(“31-Dec-”+int2str(InvoiceYr),123))
insertEntrance = true;
conLedgerDimension = [“MAINACCOUNT”, god_Post.MainAccountId];
if(membership.PrimaryMemberRegion !="")
struct.add(‘Region’,membership.PrimaryMemberRegion );
i+=1;
struct.add(‘Group’ , ‘Membership’);
i+=1;
if(membership.Location !="")
struct.add(‘Location’,membership.Location);
i+=1;
if(membership.State !="")
Struct.add(‘Departments’,membership.State);
i+=1;
if(membership.dataAreaId == ‘nr’ )
Struct.add(‘Analysis’,‘Membership Subscription - NR’);
i+=1;
if( membership.dataAreaId == ‘er’)
Struct.add(‘Analysis’,‘Membership Subscription - ER’);
i+=1;
if( membership.dataAreaId == ‘wr’ )
Struct.add(‘Analysis’,‘Membership Subscription - WR’);
i+=1;
if( membership.dataAreaId == ‘sr’)
Struct.add(‘Analysis’,‘Membership Subscription - SR’);
i+=1;
custInvoiceTable.clear();
custTable = CustTable::find(membership.Customer);
custInvoiceTable.initFromCustTable(custTable);
custInvoiceTable.OrderAccount = membership.Customer;
custInvoiceTable.GOD_CustAddress = membership.Address;//LogisticsPostalAddress::findRecId(CustInvoiceTable.PostalAddress).Address;
custInvoiceTable.InvoiceDate = InvoiceDate;
custInvoiceTable.numberSequenceGroup = “MEM-” + custInvoiceLine.dataAreaId;// KK modifed(21-11-2014)
custInvoiceTable.GOD_InvoiceYear = InvoiceYr;
custInvoiceTable.GOD_MembershipNum = membership.MembershipNum;
// KK Modified -18/12/2014 - updating Bank Account
if( membership.dataAreaId == ‘nr’)
custInvoiceTable.GOD_BankAccount = “NR/ICICI/0420”;
custInvoiceTable.GOD_BankAccount = “SR/ICICI/4914”;
custInvoiceTable.GOD_BankAccount = “ER/ICICI/9180”;
if( membership.dataAreaId == ‘wr’)
custInvoiceTable.GOD_BankAccount = “WR/ICICI/8006”;
ledgerDimension += struct.fields();
for(j=1 ; j<= i ; j++)
ledgerDimension += struct.fieldName(j);
ledgerDimension += struct.valueIndex(j);
defaultDimension = AxdDimensionUtil::getDimensionAttributeValueSetId(ledgerDimension);
custInvoiceTable.DefaultDimension =defaultDimension;
if (membership.MembershipType == ‘International Membership’)
custInvoiceTable.CurrencyCode = ‘USD’;
custInvoiceTable.insert();
select firstOnly code
where code.ServiceCode == ‘MEMBERSHIP’;
select god_Post
custInvoiceLine.clear();
custInvoiceLine.initValue();
custInvoiceLine.initFromCustInvoiceTable(custInvoiceTable);
if (insertEntrance)
if (mthOfYr(membership.DateOfJoining ) <= 3 )
quaters = ‘Q1’ ;
else if (mthOfYr(membership.DateOfJoining ) >= 4 && mthOfYr(membership.DateOfJoining ) <= 6 )
quaters = ‘Q2’ ;
else if (mthOfYr(membership.DateOfJoining ) >= 7 && mthOfYr(membership.DateOfJoining ) <= 9)
quaters = ‘Q3’ ;
else if (mthOfYr(membership.DateOfJoining ) >= 10 && mthOfYr(membership.DateOfJoining ) <= 12)
quaters = ‘Q4’ ;
select goD_BillingCycle where goD_BillingCycle.Quarter == quaters;
switch (membership.MembershipType)
case “Primary Membership” :
if (membership.FixedSubscriptionCheck == NoYes::Yes)
custInvoiceLine.AmountCur = membership.FixedSubscriptionAmount;
// KK Modified - 17/12/2014
custInvoiceLine.Description = strFmt(‘Membership Subscription for ’ + int2str(InvoiceYr) + ’ CII(’ + CompanyInfo::findDataArea(membership.dataAreaId).Name + ‘)’ + ’ Period :’ +‘1- jan- ‘+ int2str(InvoiceYr)+’ to’ + ’ 31-Dec- ’ + int2str(InvoiceYr) + ’ On gross sales turnover 31 - March ’ + int2str(InvoiceYr-1) + ’ Rs.____________________’);// + int642str( custInvoiceLine.AmountCur) );
// KK Modified -17/12/2014
else
select gOD_GrossSalesTurnover WHERE gOD_GrossSalesTurnover.MembershipNumber == membership.MembershipNum
&& gOD_GrossSalesTurnover.ToYear == (InvoiceYr -1);
select lastGSTAmount order by fromyear desc where lastGSTAmount.MembershipNumber == membership.MembershipNum
&& lastGSTAmount.ToYear <= (InvoiceYr)
&& lastGSTAmount.GST != 0;
DiffYear = InvoiceYr - lastGSTAmount.ToYear;
if (gOD_GrossSalesTurnover.GST )
calculatedAmount = gOD_GrossSalesTurnover.GST;
gstAmount = true;
else
calculatedAmount = gOD_GrossSalesTurnover.NotionalGST;
nGstAmount = true;
select gOD_PrimaryMemSubscriptionRate where gOD_PrimaryMemSubscriptionRate.From <= calculatedAmount
&& gOD_PrimaryMemSubscriptionRate.TO >= calculatedAmount;
if (goD_BillingCycle.PercentageOfSubcription /100 > 0)
custInvoiceLine.AmountCur = gOD_PrimaryMemSubscriptionRate.SubscriptionAmount * goD_BillingCycle.PercentageOfSubcription /100 ;
if ( gstAmount == true)
custInvoiceLine.Description = strFmt(‘Membership Subscription for ’ + int2str(InvoiceYr) + ’ CII(’ + CompanyInfo::findDataArea(membership.dataAreaId).Name + ‘)’ + ’ Period :’ +date2str(membership.DateOfJoining,123,1,3,3,3,2)+’ to’ + ’ 31-Dec- ’ + int2str(InvoiceYr) + ’ On gross sales turnover 31 - March ’ + int2str(InvoiceYr-1) + ’ Rs.’ + int642str(calculatedAmount) );// KK modified(31-March added) on 16/12/2014
else if (nGstAmount == true )
custInvoiceLine.Description = strFmt(‘Membership Subscription for ’ + int2str(InvoiceYr) + ’ CII(’ + CompanyInfo::findDataArea(membership.dataAreaId).Name + ‘) Period : ’ + date2str(membership.DateOfJoining,123,1,3,3,3,2)+ ’ to’ + ’ 31-Dec-’ + int2str(InvoiceYr) + ‘On Estimated Gross Sale Turnover During the Year End 31 - March ’ + int2str(lastGSTAmount.ToYear) + ’ Rs.’+ int642str(lastGSTAmount.GST)) + ’ Add :(Rule 10 Explanation(V) of The Confederation As Amended on 1st January,1997 20% increase in Sales Turnover In Each year for the Last’ +int2str(DiffYear -1) + ’ year(s) cumulative Rs.’ + int642str(gOD_GrossSalesTurnover.NotionalGST-lastGSTAmount.GST)+ ’ Gross Sales Turnover for the purpose of current years membership subscription Rs.’ + int642str(gOD_GrossSalesTurnover.NotionalGST);
else
custInvoiceLine.AmountCur = gOD_PrimaryMemSubscriptionRate.SubscriptionAmount ;
custInvoiceLine.Description = strFmt(‘Membership Subscription for ’ + int2str(InvoiceYr) + ’ CII(’ + CompanyInfo::findDataArea(membership.dataAreaId).Name + ‘)’ + ’ Period ’ +‘1- jan- ‘+ int2str(InvoiceYr)+’ to’ + ’ 31-Dec- ’ + int2str(InvoiceYr) + ’ On gross sales turnover during the year end 31 - March’ + int2str(InvoiceYr-1) + ’ Rs.’ + int642str(calculatedAmount) );// KK modified(31-March added) on 16/12/2014
custInvoiceLine.Description = strFmt(‘Membership Subscription for ’ + int2str(InvoiceYr) + ’ CII(’ + CompanyInfo::findDataArea(membership.dataAreaId).Name + ‘) Period : ’ + ‘1- jan- ‘+ int2str(InvoiceYr)+ ’ to’ + ’ 31-Dec-’ + int2str(InvoiceYr) + ‘On Estimated Gross Sale Turnover During the Year End 31 - March ’ + int2str(lastGSTAmount.ToYear) + ’ Rs.’+ int642str(lastGSTAmount.GST)) + ’ Add :(Rule 10 Explanation(V) of The Confederation As Amended on 1st January,1997 20% increase in Sales Turnover In Each year for the Last’ +int2str(DiffYear -1) + ’ year(s) cumulative Rs.’ + int642str(gOD_GrossSalesTurnover.NotionalGST-lastGSTAmount.GST)+ ’ Gross Sales Turnover for the purpose of current years membership subscription Rs.’ + int642str(gOD_GrossSalesTurnover.NotionalGST);
custInvoiceLine.InvoiceTxt = custInvoiceLine.Description ;
break;
case “Multiple Membership” :
SELECT gOD_GrossSalesTurnover WHERE gOD_GrossSalesTurnover.MembershipNumber == membership.MembershipNum
DiffYear = InvoiceYr - gOD_GrossSalesTurnover.ToYear;
else
calcValue = gOD_PrimaryMemSubscriptionRate.SubscriptionAmount * 15/100;
if (calcValue >= 2000)
