blocked session
How can i unblock a blocked session without restarting Navision Server?
Can you be more specific as to what’s ‘blocked session’. If you mean a currently connected Session. Then in Std. Nav. there are no solutions but there are some other solutions(Session Killer) in download section here. You can check? Regards[8D]
Ok, Mohammad. I’m working with a NF client session and my network connection breaks. Then the session is blocked and i can’t work with it althoug the network connection works again, and i have to start a new session. The only way i found to unblock the blocked session is to restart the NF server. I’m end user and i think i have not permissions to instal session killer. Any other solution? Regards.
Hi. Please use the search function. This has been discussed several times before.
quote:
To be more specific: Search for ‘Keep alive time’. This should resolve your problems, even if you are an ‘End User’. Regards Walter
Thanks Walter. Saludos. (Regards)
