hello , we use the dimensions ,
and lets say I have an old dimension that I don’t want anyone to use it ,
how can it be done ?
If it is Dimension values, click on suspend on that value. If it is a dimension in itself, update COA structure.
Pranav…
it a dimension value … how do i click suspend ?
what is it coa ?
COA = Chart of Accounts
Assuming you’re referring to a dimension value…
GL > Setup > Financial dimensions > [Select the dimension] > [Click Financial dimension values] > [Select dimension value] > [In the General Tab, check Suspend]
Tyler
gl (ok) > setup (ok) > where is it fimamcial dimension
i have ax 2009
i have ax 2009
