blank lines in a report
good morning one and all,
i want to print a blank lines in a report(classic),is it possible
can any one suggest me please…
thank you
Can you be nore clear please?
sir,
i am having the report
i want to print the blank lines in the body section,
description,quantity,quantity,unitprice(fields in header)
data in the body(foreign tour operator,1,10,000,400)
after the data in the body section ,i want to print some blank lines in the body as shown below
footer section as shown below…
here i am facing with the problem with in the body section.
the header and footer are in correct format.
i want to print 10 blank lines after the data in the body…
i have taken sales invoice header,integer as data items
as shown below,can you suggest me please
Your frnd has already posted here.
http://dynamicsuser.net/forums/t/59650.aspx
Please search the forums…
thanks for your kind reply,
i dont know about the fixed line forum sir…
but in mibuso you have given some code…
Pages := NoOfLines DIV 25;
NoOfLines := NoOfLines - (Pages * 25);
SETRANGE(Number,1,NoOfLines);
i have tried this code in the following manner
i have taken two dataitems
and i have written some code in presection of integer as shown below;
onpresection();
NoOfLines :=10;
i have taken one textbox in body section and assigned source expression as no of lines.
it is showing output as shown below…
can you please suggest me ,i am stopping with this issue
25 is the No. of lines required for that particular user…
its not standard code
ya sir,
i got the blank lines for alternative pages(1,3,5…)i am having about 1800 pages;
as shown below …;
but actual my requirement is i want to get blank lines on every page…is it possible …can you suggest me.
thanks
Yes, it is possible.
You need to calculate how many blank lines you required based on total lines and lines in sales invoice lines
and set filter on integer dataitem from 1 to required lines.
good evening sir,
i have tried with using setfilter
Integer - OnPreDataItem()
Integer.SETFILTER(Integer.Number,‘1…10’);
and there by i have taken integerbody in sections and i have assigned a shape ,in the integer body section;
the output is as shown below,this is what i required;
but coming to actual real time project, i have done same things in the report,but i am not getting the output;
i sharing the actual data items in my projects;
DataItem Name
Sales Invoice Header
Integer CopyLoop
Integer PageLoop
Integer DimensionLoop1
Sales Invoice Line < Sales Invoice Line>
Integer Sales Shipment Buffer
Integer DimensionLoop2
Integer VATCounter
Integer VatCounterLCY
Integer T otal
Integer Total2
in which data iem i hve to write the code,can you please suggest me …
i have sales invoice line header,body,footer;
i want these blank lines under sales invoice line body…after that footer must be displayed…
i have written this code in sales shipment buffer(integer) dataitem but it was not coming
can you suggest me please;
