I would like to make a report where some fields have black background and white text. If I in the properties of the field set “Forecolor=16777215”, “Backcolor=0” and “BackTransparent=No” then the field looks correct in design mode, but the print is still black text on a white background. Does anyone have a solution?
Unfortunately Navision reports cannot print text in colour. The only objects that get printed in colour are bitmaps.
maybe you can incorporate something like this & modify it to spruce up your report. Using gray instead of black? http://www.mibuso.com/dlinfo.asp?FileID=272
