What are the system requirements for Biz Talk Server in relationship to Navision v3.7? Do I need a Biz Talk Server if I move towards Commerce Portal (eCommerce)? Thanks, Steve
. . .For eCommerce in 3.7 why not implement an ASP3/.NET solution with the SQL Database option?
You have several things to consider when implementing BizTalk. Your transaction throughput is important and the method that external partners will send messages will also impact your decision. If you are just looking for a test environment, then you only need SQL Server 2000, BT Server 2002, .NET Framework, and the CG components. Commerce Portal is a completely separate product that does not use BizTalk in its architecture
