Billl oF Ladings being deleted in Navision when 945 received
Hello,
Can someone help me with this 945 issue :
The BLs are being deleted when we receive a 945 from 3PL. It appears that the inventory is being adjusted properly and invoices are generated correctly. Some other BLs so affected are:
771191 771188 771204 771207
771213 771205 771206 771369
Would anyone know why this is happening. How can I fix it???
Do you mean to say that after invoicing the po/bl getting deleted?
if it is so then yes it is getting deleted once you receive entire qty
How can this be fixed in Navision ??
Set EverythingInvoiced := FALSE in Codeunit 90.
This will stop deleting PO after completely Invoiced/Received.
