I have defined a variable of the DataType BigText in a Report.
I have used ADDTEXT to concatenate several smaller texts to my BigTextVar.
Problem arises when I try to print BigTextVar using FORMAT(BigTextVar) as the SourceExpr in a TextBox.
I get an error saying that “The following text cannot exceed a total of 1222 characters.” BigText is supposed to be able to hold 2 thousand million characters. And TextBox has a MaxLength of 2048 characters as default.
Does anyone know what is going on here? Does anyone have a solution?
Your only cances to print such a long text is actually to split into seperate lines (either in a record or in an array) and print the information line-wise
Or you use an external reporting tool which supports strings with unlimited length.
The FORMAT function only works for simple types. BigText is a complextype. Where do youy need the FORMAT for?
What you can do is: Define a function that returns a ordinary text variable, and select the part of the bigtextvar that is needed. Then you can use the function as the source expression.
