Hi Rana, You could have one item in all Item 1: UOM Base PCS, Tray, Box When you create the BOM for the PCS, Add all the items in the Ratio Item 2: 1 Item 3 : 1 Tray : 1/6 Box : 1/12 Etc. When you have a production order then You post consumption based on the type of order. Each of the Different UOM can also be a variant for you to identify what BOM components you can use.
Dear Prashycool, Thank you for your reply, I apreciate it, but as I told Andreas before for the same suggestion, my BOM production differs according to the orders. To check more about it plse refer to my reply for Andreas. thank you. As for wht you have said: “Each of the Different UOM can also be a variant for you to identify what BOM components you can use.” may you illustrate it a little bit for me? Thank you all.
