Best class to read csv file
Hello guys,could you please suggest best class to read csv file in ax 2012 R3.
I found below classes.
IO
CommaTextIO
Thanks in advance.
Hi ,
You can use CommaIO and AsciiIo Classes…
The following Links may helpful to you…
https://msdn.microsoft.com/en-us/library/commaio.aspx
https://community.dynamics.com/ax/f/33/t/111112
Hi ,
To read csv files you can use CommaIo Class…
CommaIO has been replaced by CommaTextIO.
Nevertheless the usual approach is using the Data Import Export Framework instead of writing custom code.
Thanks for the Reply
Thank you
Try this for Exporting waytoax.wordpress.com/…/
also for Importing waytoax.wordpress.com/…/
