BC Demo No Permission to Run 'Design, CodeUnit, Basic' System
Hi everybody,
I’m having a problem to maintain development objects from CSIDE.
It’s a demo environment running on Docker on Windows Server on Azure.
But if i create objects let’s say a code unit from VS Code it can be deployed successfully.
Please advise.
You need to load your own development license, before you can edit anything with the development environment, which is outside of the default demo license that you currently have loaded.
Thanks Erik!
