Batch Job not starting
I created a batch job in Dynamics AX 2012 R3and set its status to ‘waiting’. But it is always in waiting state, never changed into ‘executing’ state. I have assigned batch group also.
Please help me.
Thanks in Advance!!!
Does the batch group has batch server assigned to it?
Thanks kranthi for reply.
yeah batch server were assigned.
Is this a problem with one batch or all the batch jobs? If all, check the batch server configuration also, technet.microsoft.com/…/gg731831.aspx
How did you created this batch job?
Your batch job might still be in waiting state because may be the batch server to which your batch group points, has reached maximum number of threads in EXECUTING state (as per the server configuration),
checked in batch server configuration. after checking Is batch server in Server configuration.
It Works fine.
Thanks Kranthi!!!
