Batch Job Log
Can anyone tell me if it’s possible to pull the text from a batch job log into a text file (or a variable) on the batch job grid via code? I’m specifically trying to pull it on specific logs that error, so I can email an admin the log with the errors.
Thanks!
Try this…
static void Job12(Args _args)
int i, countItems;
InfologData data;
BatchJobHistory BatchJobHistory;
select BatchJobHistory where BatchJobHistory.RecId==5637468836;
if (batchJobHistory && batchJobHistory.RecId)
data = BatchJobHistory::showLog(batchJobHistory.RecId);
countItems = conlen(data);
for(i=1;i<=countItems;i+=3)
print (info::infoCon2Str(conpeek(data, i+2)));
pause;
Also consider using alerts. Open the Batch job form, select a batch, press Alerts button, tick Error and E-mail and confirm.
