Hello,
Can you have batch attributes in a items field, or is that just used in batch ordering? How do I go about putting batch attributes in an items field?
I’m using AX 2009, if that helps.
Thank you!!
Hello,
Thank you!!
I believe that the batch attribute options were only standard in AX2012, or if you purchased the FullScope Process add-on for AX2009. They are attached to the tracking dimension of batch and can be updated from quality orders etc.
