I have 2 simple problems that I cannot solve (due to having no documentation):
- I have an DateEdit text field on a form - I have overwritten a ‘clicked()’ attached to a button on the form - when I click the button, I just want the date in the DateEdit text field to appear in a box::info… How do you grab that date value from the text field? I have tried referencing the DateEdit text field directly, and get the following error:
*** Error: 7, the table does not contain this field.
I have also tried supplying a default value, by associating the DateEdit text field with a table (this supplies the little calendar box you can click on, then select a date) - this does not error - but the recid is always zero/null - I cannot get the clicked() method to understand that I want to get the date from this field - anyone know how this is supposed to be done?
Thanks in advance
