Hi
My task is to make a label with a barcode. I have tried some different technical solutions but keep running into some issues when scanning the label afterwards
I am using MS Dyn NAV 2009 R2 Classic on Windows 7 client
PDF1 (Test1 att.) is generated via BullZip printerdriver from NAV. The barcode itself is created as a .bmp and put on the labelreport. This one I am not able to scan with my labelscanner
I open the above PDF and print it to Cute PDF printerdriver and saves the file into a new PDF (Test2 att.). This one I am able to scan
Can anyone tell me, what happends when I open and saves into new file? Is there any settings I can set in BullZip the first time I create the pdf, to make it scanable?
Test1
Test2
Best Regards
Mads Morre
