Barcode adding into report in Saas
Hello eveyone,
I’m trying to generate stickers with barcodes in BC SaaS. I’ve found a barcode font installed into my laptop time ago, and I’ve tried with it. Visually seems OK, but when printing and trying to read with a barcode scanner, we don’t get anything. Any hint on how to insert barcodes into reports?
Thank you all
Are you using a Code 3 of 9 barcode font? If so have you wrapped the text you’re trying to output with asterisks?
I.e. text = CODE123
Barcode text = CODE123
If you’re trying to do other barcode types, e.g. Code 128 or UPC/EAN they require more work to format the data, it’s not as simple as selecting a barcode font.
Thank you Paul, that was it!!
