Bar Code
Hello All
Can any one tell me about Bar code.
How it will work and is any PDF regarding
that in Navision or any topic whom i can
know more about BAR CODE…
Please if any PDF for that kindly provide the link…
or customization techniques.
Hi
For barcoding there are bar code fonts available, we have to buy one and install. On Navision report we can use those fonts and print barcode. To read barcode, when the bar code scanner is connected to the machine, system can can read it just like any other input device ie. keyboard.
Cheers!!!
Hello Dear
Actually i wanted to create the Bar code for my item
and i don’t know how it will???
so please if u hv any PDF regarding that send me…
Thanks for replying
devesh
Devesh,
You should not need any PDF or document for this. This is pretty simple. You need to do following:
  1. Download a bar code font (or if not free then buy and install). You may try following link:
http://www.barcodesinc.com/free-barcode-font/
  1. Then create your report as normal and for the field for which you want to print BarCode, change its font (Shift+F4, and then font ) to your barcode font.
Hope this helps
Hello Dear
Actually i try the method that u tell but still it can’t work
can u please clarify for me.
I had the same problem and this is how i fixed it.
I use a code 39 barcode (free idautomation) which muxt have a * leading and trailing charachter. Code 39 is recognized by every scanner. So I create a variable:
SOBarcode := ‘’ + “Sales Header”.“No.” + '’;
If you use a EANUCC these barcodes must be encoded before printed.
I think this varies from scanner to scanner. Recently I know someone, for whose scanner ` was the leading character and ~ was trailing character. But the idea of printing barcode remains same as mentioned in my previous post. Please correct me if I am wrong.
Another Option is an outside program or you can do it thru c/al code.
See Here: http://www.mibuso.com/dlinfo.asp?FileID=1192
If you scroll down to the related downloads you’ll see other options for different types of barcodes.
EAN8
EAN13
Code 3of9
Code 128
Code 128B
Code2of5
Etc…& The barcode generator does 24 different types.
