I’m looking for support for Bankgiro such as invoice export and payment registration using a dataport or a codeunit. There are rumors that there is a ready-to-wear version that you simply need to install, config and run
Since you seem to be located in sweden: Banking is available in the latest SE3.60… otherwise most NSC’s use the BASE add-on, for preferably Financials versions, which will give giro handling. (pretty huge text there :D) /LG
Hello Hrillo Are you a customer or NSC’s if you are the latter I can send you a report that creates a text file. This is one of my first programs so its not pritty, but I do have it working using ActiveX togeather with BGCOM. Regards Graham
