How to transfer amount from one bank to other, which are having different currencies in AX 2012 .Is it possible?? If possible how to use the flexible exchange rates in those transactions??
On the bank master, put check mark on more currencies. This will enable you to post transactions in any foreign currency.
Use general journal to post the transfer. System will by default take the exchange rate as per setup which can be overwritten at the journal level which will override existing exchange rate.
