Hi, Axapta 3.0 SP1 is well working in 2-tier. We try to deploy 3-tier with AOS. Well, the application took a very long time to start on each client now ! The network latency between each component is under 10 ms (ping between AOS - Database - Client - AOS - Application Server). The thing is that there is no host file on AOS because we use 2 WINS servers. Is there any other raison for such a gap between 2-tier and 3-tier ? Thank you for interest. Thierry
Try this: set the AOS host name as an IP-address in the client settings and test again. What hapens?
We had the same issue with Axapta 3.0. In the Axapta Object Server settings, go to the Database tab and uncheck the initialize database for Unicode option.
