Hello, all. We’re running Attain 3.01, but objects are not actually converted from 2.60. Whole database backup consists of 8 files 2Gb each, actual DB size is close to 127 Gb (I know that it’s dangerous enough, but we’re moving to SQL option soon). The problem is following: during the restoring the database, at the stage of key building, Attain client hangs up with message Error 1355 in module 19 - DBMNotReentrant. Can anybody tell me, what this error means? How can I avoid it? Thanks in advance. With best regards, Maxim.
I had the same error. It was fixed by adding more space to the TEMPPATH destination. Make sure that you have approx. as much free space as the size of your database.
